Method - Lowess
The lowess routine calculates a new, smoothed y-value for each x-value.
1    The routine selects a fraction (default f = 0.5) of all points, using the data closest in x-value on either side of the (x,y) point. The selection often results in more points selected from one side of the x-value than the other. The example below shows the fraction of data selected for a given point:
The shaded area holds the 0.5 fraction
closest to the solid red data point.
Y-Values
X-Values
2    Minitab calculates weights using the x-distance between each point in the selected fraction and the point to be smoothed:
weight = [1 - (
distance from the selected point
max distance between selected point and the (f·n) points
)3]3
This equation produces weights for the fraction of selected points that have the following relationship:
X-range for the fraction
Weights
X-Values
Points closest to each x-value have the greatest weight in the smoothing.
3    Minitab performs a weighted linear regression on all points in the selected fraction of the data, using the weights from step 2 to produce an initial smoothed value.
4    Finally, the Minitab limits the influence of outliers on the results by using further iterations (default n = 2) of step 3 (called "robust steps"), with new weights calculated as follows:
weight = [1 - (
|residual for the point from previous step|
6 (median of all |residuals| from previous step)
)2]2
