... > Data View > Data Display
Use to represent the data with one or more data display types, including areas, contour lines, and symbols. After creating a graph, you can:
More |
Use Tools > Options > Individual Graphs > Contour Plots > Options to set the default data display. |
Data Display
Area: Check to shade the areas between contours.
Contour lines: Check to draw contour lines.
Symbols: Check to represent each x-y data point with a symbol.
