You can represent the data with areas, contour lines, and symbols. In the Example of a contour plot, you determine the optimal time and temperature for reheating a new frozen entree. You want to customize the data display.
Area (default) and contour lines 1 Open the worksheet REHEAT.MTW. 2 Choose Graph > Contour Plot. 3 In Z variables, enter Quality. In Y variable, enter Time. In X variable, enter Temp. 4 Click Data View. 5 Under Data Display, check Contour lines. 6 Click OK in each dialog box. |
Area (default) and symbols 1 To recall the last dialog box, press [Ctrl]+[E]. 2 Click Data View. 3 Uncheck Contour lines. 4 Check Symbols. 5 Click OK in each dialog box.
