You can represent the data with symbols, connect lines, and project lines. You can also fit a lowess smoother to the data. If you have grouping variables, Minitab assigns different attributes to each group and displays a legend. In the Example of a simple time series plot, you track a company's quarterly sales over three years. You want to customize the data display.
Symbols (default) and project lines 1 Open the worksheet NEWMARKET.MTW. 2 Choose Graph > Time Series Plot. 3 Choose Simple, then click OK. 4 In Series, enter SalesB. 5 Click Time/Scale. 6 Under Time Scale, choose Calendar. Then choose Quarter Year. 7 Under Start Values, choose One set for all variables. 8 Under Quarter, type 1. Under Year, type 2000. Click OK. 9 Click Data View. 10 Uncheck Connect line. Check Project lines. 11 Click OK in each dialog box. |
