To change the data display
examples
1    In the graph dialog box, click Data View.
2    Click the Data Display tab.
3    Under Data Display, check one or more of the following:
·    Bars to display bars that join each data value to its base. By default, the height of each bar is equal to the frequency of the interval it represents.
·    Symbols to represent each data value with a symbol.
·    Project lines to display lines that project from each data point to its base.
·    Area to draw a histogram with an outline of the bars (only visible if you uncheck Bars).
4    Click OK in each dialog box.
