You can represent the data with bars, symbols, project lines and areas. You can also fit a distribution and a lowess smoother to the data. In the Example of a simple histogram, you determine the amount of torque required to remove shampoo bottle caps. You want to customize the data display.
Bar (default) and symbols 1 Open the worksheet CAP.MTW. 2 Choose Graph > Histogram. 3 Choose Simple, then click OK. 4 In Graph variables, enter Torque. 5 Click Data View. 6 Check Bars and Symbols. 7 Click OK in each dialog box. |
Area 1 To recall the last dialog box, press [Ctrl]+[E]. 2 Click Data View. 3 Uncheck Bars and Symbols. 4 Check Area. 5 Click OK in each dialog box.
