Multiple Variables
overview
    how to
example     see also
... > Multiple Graphs > Multiple Variables
Controls the placement and scales of multiple graphs created in the same graph dialog box. After creating a graph, you can:
·    Change the variables used to create the graphs. See Make Similar Graph.
·    Change the characteristics of the panels. See panel editing.
·    Change the scales used on each axis. See Scale Editing Overview.
Show (Pairs of) Graph Variables
Overlaid on the same graph: Choose to overlay graphs on the same data region. See Overlaying Graphs.
In separate panels of the same graph: Choose to display each graph in a separate section of the same page. See Paneling Graphs.
On separate graphs: Choose to display each graph in its own graph window.
Same Scales for Graphs: Only available when you choose In separate panels on the same graph or On separate graphs. Available options depend on the graph.
Same Y: Choose to use the same y-axis scales for all graphs.
Same X: Choose to use the same x-axis scales for all graphs.
Same number of data values per dot: Choose to make dots on separate graphs share data values.
Same X, including same bins: Choose to use the same x-axis scales and bins for all graphs.
<By Variables>
