... > Scale > Reference Lines
Use to display reference lines when you create a graph with a scale displaying categorical data. By default, Minitab displays labels for each reference line. After you create a graph you can:
Show reference lines at Y values: Type the y-scale values for displaying reference lines.
Show reference lines at category scale positions: Type the category-scale values for displaying reference lines. Each category is assigned an integer value. From left to right, the first category is 1, the second 2, and so on. Entering a value of 1.5 draws a reference line between the first and second categories.
