Scale elements provide important points of reference for your data. Each scale consists of an axis line, an axis label, tick marks, and tick labels, although you may not display all these components. Available scale items vary depending on:
After creating the graph, you can:
Scale item |
Example |
Specify the placement and display of axes and ticks. | |
Display major and minor gridlines for both horizontal and vertical axes. | |
Display reference lines on both horizontal and vertical axes. | |
Display percentile lines on probability plots and Empirical CDF graphs. |
Control time scales and start values with time series plots, area graphs, and control charts. | |
With graph editing, add a secondary scale to overlaid scatterplots and time series plots. |
