You can see the effect of these commands on a selected object in the following illustrations:
Before |
After choosing Editor > Annotation > Send to Back |
On the left, the rectangle obscures the text string. On the right, the text is in front. Choose Editor > Annotation > Bring to Front to restore the polygon to the way it was at left.
Tip |
If you cannot select an object because another is in front, select the object in front, send it to the back, then select the first object. You can also choose the item from the list of selectable items on the graph tools toolbar. |
