Tools > Toolbars > Graph Editing
Use the graph editing tools to select, add, or delete graph items, choose different editing modes, or zoom in or out on the active graph. To hide this toolbar, choose Tools > Toolbars > Graph Tools.
Toolbar item |
Use to... |
Select a graph item for editing. |
Bring up editing dialogs for the selected item. |
Put the active graph in select mode. |
Put the active graph in brush mode. |
Put the active graph in crosshairs mode. |
Put the active DOE contour plot in plant flag mode. |
Change the active DOE optimization plot from crosshairs mode to interactive mode. |
Select a graph item to add. Depending on the item, Minitab may prompt you for more information. |
Delete the selected item. |
Make the graph appear larger or smaller with the zoom option. |
