There are three methods for selecting graph elements. Depending on the item, you may find one easier than another.
1 Click , the
selection tool on the Graph Editing toolbar.
2 Click the object on the graph.
1 Choose Editor > Select Item, and then choose from the list.
1 Choose the object from the Graph Editing toolbar drop-down list of editable items.
Selected objects have handles:
When you select symbols, they display two handles. See Selecting groups and single items. |
Text strings have handles at vertices (corners) and at line midpoints of a rectangle that surrounds them. See Selecting groups and single items. |
Unrotated rectangles, squares, ellipses, and circles have handles at vertices (corners) and at line midpoints. For circles and ellipses, the vertices and endpoints are located on a rectangle that surrounds the object. |
Selected polygons have handles at each vertex. |
Tip |
If you cannot select an object, it may be because a second object is in front of it. Select the object in front, choose Editor > Send to Back, then select the first object. See Bring to Front and Send to Back. |
