You can select all points on a graph, a single group, or a single point. This method can also be used to select other graph objects:
Available editing options may depend on whether you have selected a group or a single item. |
Click on a graph point once to select all points. |
Click the point a second time to select only those points within the group. |
Click a third time to select the individual point. |
