Your company manufactures frozen foods and you need to determine the optimal time and temperature for reheating a new frozen entree. You reheat samples at a number of different times and temperatures, then have trained judges rate each for overall quality on a scale of 0 (not enjoyable) - 10 (most enjoyable). Create a 3D surface plot to examine the results.
Create a 3D surface plot 1 Open the worksheet REHEAT.MTW. 2 Choose Graph > 3D Surface Plot. 3 Choose Surface, then click OK. 4 In Z variable, enter Quality. In Y variable, enter Time. In X variable, enter Temp. 5 Click Scale, then click the Gridlines tab. 6 Under Show gridlines for, check Z major ticks, Y major ticks, and X major ticks. 7 Click OK in each dialog box. |
Reheating at the shorter time intervals results in under-cooked product and low quality scores. However, reheating at the longest intervals combined with the highest temperatures also results in low scores because the food becomes over-cooked.
Adding the gridlines helps you visualize the peaks and valleys of the surface and determine the corresponding x- and y-values.
Rotating the graph to view the surface from different angles can help you visualize the peaks and valleys of the surface.
Rotate the plot 1 If the 3D Graph Tools toolbar is not visible, choose Tools > Toolbars > 3D Graph Tools. 2 Click and hold the |
Rotating the graph helps accentuate the ridge of high z-values centered at about Time 35 and Temp 425.
Changing the graph lighting can help reveal different features of the data surface.
Rotate the lights 1 Click and hold the |
Rotating the lights to illuminate the low Time-Temp face of the ridge helps define its features. There appears to be a peak at about Time = 35 and Temp = 400.
Additional examples that help visualize these data include:
