Bubble Plot - Simple
     how to     example     data     see also
Graph > Bubble Plot > choose Simple > OK
Use to display a bubble plot.
Y variable: Enter the column of y-values.
X variable: Enter the column of x-values.
Bubble size variable: Enter the column of values that determine the size (area) of the bubbles.
Panel variables (optional): Enter up to two columns of categorical variables for paneling. Minitab displays a panel for each distinct combination of values, all on the same graph.
Note
You can customize the size and other attributes of bubbles after you create the graph. Select the bubbles and choose Editor > Edit Bubbles.
<Scale>
<Labels>
<Data Options>
