To display a bubble plot
    example
data     see also
1    Choose Graph > Bubble Plot.
2    Choose Simple, and then click OK.
3    In Y variable, enter the column of y-values.
4    In X variable, enter the column of x-values.
5    In Bubble size variable, enter the column of values that determine the size (area) of the bubbles.
6    If you like, use any dialog box options, and then click OK.
