Graph > Bubble Plot > choose With Groups > OK
Use to display a bubble plot that has groups that are identified by bubbles of different colors.
Y variable: Enter the column of y-values.
X variable: Enter the column of x-values.
Bubble size variable: Enter the column of values that determine the size (area) of the bubbles.
Categorical variables for grouping (optional): Enter up to three columns of categorical variables for grouping. Minitab displays all groups on the same graph.
Panel variables (optional): Enter up to two columns of categorical variables for paneling. Minitab displays a panel for each distinct combination of values, all on the same graph.
You can customize the size and other attributes of bubbles after you create the graph. Select the bubbles and choose Editor > Edit Bubbles. |
