1 Choose Stat > ANOVA > Interval Plot or Graph > Interval Plot.
2 Under Multiple Y's, choose With Groups. Click OK.
3 In Graph variables, enter one or more columns of data to plot. Minitab plots each column on the same graph.
4 In Categorical variables for grouping (1-3, outermost first), enter one to three columns of grouping (categorical) variables. The first variable is the outermost categorical variable on the scale and the last variable is the innermost categorical variable.
5 Under Scale Level for Graph Variables, choose one of the following:
6 If you like, use any dialog box options, then click OK.
