1 Choose Graph
> Pie Chart.
2 Do one of the following:
· If
you have one or more columns of raw categorical data,
choose Chart raw
data. Enter the columns
of categorical data in Categorical variables.
Minitab displays a separate pie chart for each column, on the same graph.
(To display each pie chart on a separate graph, use Multiple
Variables.)
· If
you have one column of categorical data
with accompanying summary data,
choose Chart values
from a table. In Categorical variable, enter the category
column. In Summary variables,
enter one or more columns of corresponding summary data.
3 If you like, use any dialog
box options, then click OK.
