1 Choose Graph > Probability Distribution Plot > choose Two Distributions> OK.
2 From Distribution 1, choose a distribution.
3 Enter one parameter per box. The specific parameters change depending on the distribution you choose.
4 From Distribution 2, choose a distribution.
5 Enter one parameter per box. The specific parameters change depending on the distribution you choose.
6 If you like, use any dialog box options, then click OK.
