Use these graphs to explore relationships between one or more pairs of variables. For example, you can assess:
Graph |
Uses |
Scatterplot |
Use a scatterplot to assess the relationship between two variables. The values of the two variables serve as the x- and y-coordinates for plotting each observation. Display options include fitted lowess and regression lines. |
Matrix Plot |
Use a matrix plot to assess the relationships among several pairs of variables at once. A matrix plot is an array of individual scatterplots. Display options include fitted lowess and regression lines. |
Bubble Plot |
Use a bubble plot to explore the relationships among three variables on a single plot. Like a scatterplot, a bubble plot plots a y-variable versus an x-variable. However, the symbols (also called bubbles) on the bubble plot vary in size. The area of each bubble represents the value of a third variable. |
Marginal Plot |
Use a marginal plot to assess the distributions of two variables as well as the relationship between them. A marginal plot is a scatterplot with histograms, boxplots, or dotplots in the margins. |
