Minitab provides a flexible suite of graphs to support a variety of analysis needs. Many customization options are available when you create a graph and many more are available after you create it.
Use the following chart to select a graph from the Graph menu that fits your needs:
To ... |
Use ... |
Histogram, Dotplot, Stem-and-Leaf, Probability Plot, Empirical CDF, Probability Distribution Plot, or Boxplot | |
Boxplot, Interval Plot, Individual Value Plot, Line Plot, Bar Chart, or Pie Chart | |
Contour Plot, 3D Scatterplot, 3D Surface Plot, or Bubble Plot |
In addition to the graphs available from the Graph menu, Minitab offers analysis-specific graphs on the Stat menu, such as control charts. Minitab also has built-in graphs as part of many statistical analyses. Character graphs are available, but do not appear on a menu by default (with the exception of Stem-and-Leaf). To add character graphs to a menu, use Tools > Customize > Command.
Customization options differ by graph, but most dialogs have the following options:
Option |
Use to ... |
Add or customize axes and ticks, gridlines, reference lines, and other scale elements. | |
Add or customize titles, footnotes, data labels, and other label types. | |
Add or customize data symbols, connect lines, regression lines, distribution fits, and other data view elements. | |
Display relationships between multiple variables. Graph variables can be plotted on separate graphs, on separate panels on the same graph, or overlaid on the same graph. | |
Use subsetting to specify a subset of data to plot, frequency to include a frequency column, and group options to specify how to handle missing values and empty cells (see Missing Values and Graphs). |
Many graphs also have unique options, which are described in the Help topic for that graph.
You can also manage, arrange, and name Graph windows using the Graphs folder in the Project Manager.
