Graph Editing Overview
examples
Use graph editing to alter:
·    Attributes of graph elements
·    View or layout of graphs
·    Added graph elements and information
·    The graph itself, by updating its data or changing the variables used
Graph editing affects only the current graph. To change graphics defaults, choose Tools > Options.
After you finish editing, you can leave the graph in the current project or save it to a separate file using File > Save Graph As. If you save the graph in a Minitab Graphics Format (MGF) file, you can reopen the graph later in Minitab using File > Open Graph, then re-edit the graph. See Saving and Printing Graphs.
To enter edit mode, do one of the following:
·    Double-click the graph item to edit.
·    Select the graph item and choose Editor > Edit.
·    Select the graph item, right-click, and choose Edit.
·    Choose the graph item from the drop-down menu on the graph toolbar and click .
Graph Editing Topics
Scale Editing
Editor Menu (When Graph Window is Active)
Labels Editing
Editor Menu (When Brushing a Graph)
Data Fits Editing
Graph Tools Toolbar
Data Display Editing
3-D Graph Toolbar
Regions Editing
Graph Drawing Toolbar
Panel Editing
Graph options for matrix plot, marginal plot, bar chart, pie chart, contour plot, and 3-D surface plot.
Brushing
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
