Graphs allow you to visualize the relationships between points. After you make a graph, you often want to learn more about a point or a group of points. Brushing allows you to do this.
Initially you may find brushing useful to:
You may come away with a much greater understanding of the data after brushing, but you may also spot critical areas in a process that need immediate attention. See Brushing Features, Description, and Summary for more information.
You may find it useful to recreate your graph without the brushed points or, conversely, with only the brushed points. See Example of subsetting based on brushed points.
Brushing Item |
Example |
Brushing Tool |
A special cursor that creates a brushing region. |
Brushing Region |
Bound by a dotted line, all points that fall within this region are considered brushed. |
Brushing Palette |
A floating window that shows the Data window row number for each brushed point as well as up to ten other column values for that row. |
Brushing Markers |
Symbols in the Data window next to the row numbers indicate which rows are currently brushed. These markers are removed if the data are changed. |
