To... |
Do this... |
Choose Editor > Brush. | |
Brush points (form a new brushing region) |
1 Move
the mouse until the brushing tool 2 Drag the cursor to enclose the new brushing region. |
1 Choose Editor > Set ID Variables. 2 In Variables, enter the columns you want to use as identifiers. 3 Choose Use as default for all graphs or Use for this graph only. | |
Move an existing brushing region |
1 Place the cursor in the brushing region. 2 When
Add additional points to the brushing palette |
Do one of the following: |
Click the point. | |
Brush across Graph windows |
Brush points in one graph; the points derived from the same row are highlighted automatically in other graphs. |
Select a graph point from the brushing palette |
Click the row in the brushing palette. |
Highlight many graph points from the brushing palette |
Display/hide row numbers on the brushing palette |
1 Choose Editor > Set ID Variables. 2 Enter a column to serve as an ID variable. 3 Check or uncheck Include row numbers. |
Move the brushing palette |
Drag the palette by the title bar. |
Resize the brushing palette vertically |
Drag the lower-right corner of the brushing palette as desired. |
1 Brush the data. 2 In the data source dialog, choose Data Options. 3 Click the Subset tab. 4 Choose the appropriate options to include or exclude the brushed points. | |
Choose Editor > Show/Hide the Brushing Palette. |
