Editor Menu (When Graph Window is Active)
overview
The following commands are available when you are working in a Graph window. Choose a command for more information:
Select
Puts the active graph in select mode.
Brush
Puts the active graph in brushing mode.
Crosshairs
Puts the active graph in crosshairs mode.
Plant Flag
Puts the active contour graph in planting flag mode.
Edit
Edits the selected graph item.
Select Item
Choose from the list of items to select them for editing.
Add
Choose from the list of items to add to your graph.
Panel
Edits the paneling attributes of your graph.
Graph Options
Edits the graph options of a matrix plot, marginal plot, bar chart, pie chart, contour plot, 3D scatterplot, or 3D surface plot.
Layout Tool
Creates a multiple graph layout.
Copy Text
Copies a selected text item (titles, annotation, footnotes) or the tool tip text of a selected item to the clipboard.
Copy Command Language
Copies command language used to create the active graph to the clipboard.
Duplicate Graph
Duplicates the active graph.
Make Similar Graph
Creates a graph with characteristics identical to the active graph but with different variables.
Annotation
Choose Duplicate Annotation, Bring to Front, Send to Back, Rotate Left, or Rotate Right. Also use to show or hide the Graph Annotation Tools toolbar.
Update
Choose Update Graph Now, Update Graph Automatically, or Update All Graphs Now.
Zoom
Zooms in or out.
