Editor Menu (While Brushing the Active Graph)
overview
The following commands are available when you are working in a Graph window. Choose a command for more information:
Select
Puts the active graph in select mode.
Brush
Puts the active graph in brushing mode.
Crosshairs
Puts the active graph in crosshairs mode.
Show Brushing Palette
Select to show or hide the brushing palette.
Set ID Variables
Select to set ID variables.
Create Indicator Variable
Select to create indicator variables.
