Use these graphs to plot counts of unique values. For example you can plot:
Graph |
Description/Uses |
Bar Chart |
Use a bar chart to compare the distribution of counts across up to four categorical variables. Data can be raw (each row in a column represents one observation) or in a frequency table (category names are in one column and summary data are in another column). To compare statistics other than counts, see Comparing Summaries of a Variable. |
Pie Chart |
Use a pie chart to compare the proportion of each data value relative to the whole. Data can be raw (each row in a column represents one observation) or in a frequency table (category names are in one column and summary data are in another column). To compare statistics other than counts, see Comparing Summaries of a Variable.
