Bar Charts
overviews
     how to     examples     data
Graph > Bar Chart
Use to compare some measure of data categories. Each bar can represent a count of a category, a function of a category (such as the mean, sum, or standard deviation), or summary values from a table.
Note
 If you want to examine the shape and spread of continuous data, use Graph > Histogram.
Bars represent
Counts of unique values: Choose if you have one or more columns of categorical data and you want to chart the frequency of each category.
A function of a variable: Choose if you have one or more columns of quantitative data and you want to chart a function of the measurement data, such as the mean.
Values from a table: Choose if you have one or more columns of summary data and you want to chart the summary value for each category.
Graph gallery
The graph gallery that appears depends on your choice for Bars represent:
Values from a table
Choose one of the following options:
Counts of unique values  <back to top>
Data
Color
Density
Blue
Hi
Red
Lo
Red
Lo
Blue
Hi
Red
Hi
Red
Lo
Blue
Lo
Simple
Cluster
Stack
Counts for Color
Counts for Color by Density
Function of a variable  <back to top>
One Y
Data
Color
Density
Length
Blue
Hi
3.5
Red
Hi
4.2
Blue
Lo
2.7
Red
Lo
3.5
Blue
Lo
2.9
Blue
Hi
1.0
Simple
Cluster
Stack
Mean of Length by Color
Mean of Length by Color and Density
Multiple Y's
Data
Density
Length
Width
Hi
3.5
2.8
Hi
4.2
3.2
Lo
2.7
3.0
Lo
3.5
2.6
Lo
2.9
1.7
Hi
1.0
.85
Simple
Cluster
Stack
Mean of Length and Width
Mean of Length and Width by Density
Values from a table  <back to top>
One column of values
Data
Color
Length
Blue
3.5
Red
2.7
Simple
Length by Color
Data
Color
Density
Length
Blue
Hi
3.5
Blue
Lo
4.2
Red
Hi
2.7
Red
Lo
3.5
Cluster
Stack
Two-way table
Data
Color
Hi
Lo
Blue
3.5
4.2
Red
2.7
3.5
Cluster
Stack
<OK>
