You can add a line or curve to your graph to represent a theoretical distribution or to visualize general trends. Minitab provides three methods to model your data:
You can add a fitted line while creating a graph, or after the graph is created (see Adding Graph Elements). After creating a graph, you can change the line attributes and fit parameters (see Editing Data Fits Overview).
Data Fit |
Example |
You can fit one of 14 distributions to your data to help you determine whether the data can be adequately modeled by the selected distribution. | |
You can use a regression fit to examine the relationship between the response variable (y) and the predictor variable (x). | |
You can use a lowess smoother to explore the relationship between two variables without fitting a specific model. |
