Probability Distribution Plot
overviews
    how to     examples
Graph > Probability Distribution Plot
Use probability distribution plots to view and compare the shape of distribution curves and to view areas under distribution curves corresponding to either probabilities or data values.
View Single
Vary Parameters
Two Distributions
View Probability
View Single: Use to display a single probability distribution plot.
Vary Parameters: Use to view how varying parameters affects a distribution. Plots curves that are based on the same distribution function, but different parameter values.
Two Distributions: Use to compare curves based on two different distribution functions.
View Probability: Use to view shaded regions corresponding to a probability or x-value on a single probability distribution plot.
<OK>
