Graph > Probability Distribution Plot > choose View Probability > OK > Distribution
Use to view shaded regions corresponding to a probability or x-value on a single probability distribution plot.
Distribution: Choose a distribution.
Parameters: Enter the parameters for the chosen distribution. The specific parameters change depending on the distribution you choose.
List Box: Only used when discrete distribution is chosen.
Values In: Enter the column containing the x-values.
Probabilities In: Enter the column containing probabilities associated with the x-values.
<Options> (Geometric and negative binomial distributions only)
