Graph > Probability Distribution Plot > choose Vary Parameters > OK
Use to view how varying parameters affects a distribution. Plots curves that are based on the same distribution function, but different parameter values.
Distribution: Choose a distribution.
Parameters: Enter one or more parameters (separated by spaces) per box. The specific parameters change depending on the distribution you choose.
<Options> (Geometric and negative binomial distributions only)
