Stat > Reliability/Survival > Distribution Analysis (Right Censoring) or Distribution Analysis (Arbitrary Censoring) > Nonparametric Distribution Analysis > Graphs
You can draw survival plots, cumulative failure plots, and hazard plots.
Survival plot: Check to display a survival plot.
Cumulative failure plot: Check to display a cumulative failure plot.
Display confidence intervals on plot: Check to display confidence intervals on the survival and cumulative failure plots.
Hazard Plots: Check to display a hazard plot.
Show graphs of different variables or by levels: Choose to display the graphs overlaid on the same graph or on separate graphs.
Minimum X scale: Enter a value for the minimum X-axis scale.
Maximum X scale: Enter a value for the maximum X-axis scale.
X axis label: To replace the default X-axis label with your own label, enter the desired text in this box.
