To make a distribution overview plot (uncensored/right-censored)
main topic see also
1 Choose Stat
> Reliability/Survival > Distribution Analysis (Right Censoring)
> Distribution Overview Plot.
2 In Variables, enter the columns of failure
times. You can enter up to 50 columns (50 different samples).
3 If you have frequency columns,
enter the columns in Frequency
columns.
4 If all of the samples are stacked
in one column, check By
variable, and enter a column of grouping indicators in the
box.
5 Choose to draw a parametric
or nonparametric plot:
· Parametric
plot - Choose Parametric analysis. From Distribution,
choose to plot one of the eleven available distributions.
· Nonparametric
plot - Choose Nonparametric analysis.
If you
have no censored values, you can skip steps 6 & 7. |
6 Click Censor.
7 Do one of the following, then
click OK.
· For
data with censoring columns: Choose Use censoring columns, then enter the censoring
columns in the box. The first censoring column is paired with the first
data column, the second censoring column is paired with the second data
column, and so on.
If you like, enter the value you use to indicate
censoring in Censoring
value. If you do not enter a value, Minitab uses the lowest
value in the censoring column.
· For
time censored data: Choose Time censor at, then enter a failure time
at which to begin censoring. For example, entering 500
says that any observation from 500 time units onward is considered censored.
· For
failure censored data: Choose Failure censor at, then enter a number
of failures at which to begin censoring. For example, entering 150
says to censor all (ordered) observations from the 150th observed failure
on, and leave all other observations uncensored.
8 If you like, use any of the
available dialog box options, then click OK.
