Mean Cumulative Function and Nelson-Aalen Plot
Use the mean cumulative function and Nelson
- Aalen plot to determine whether your system is improving, deteriorating,
or staying constant.
The plot consists of:
· The
Nelson-Aalen plot, which is a plot of the empirical mean cumulative
function.
The plot points do not assume a particular model. When you have interval
data, Minitab estimates failure times by evenly distributing the number
of occurrences in each interval and plotting the appropriate points.
· The
mean cumulative function plot, which is a plot of the mean
cumulative function
based on the estimated shape and scale. For a power-law process,
the rate of system failures can increase, decrease, or remain constant.
The resulting graph can be straight or a curve that is either concave
up or down. For a homogeneous Poisson process,
the failure rate is constant, resulting in a straight line.
Because the Nelson-Aalen plot does not depend on the model, the plot
points are the same regardless of which estimation method and model type
you chose. The mean cumulative function plot, however, differs depending
on your model.
The plot provides information about the pattern of system failures:
· A
straight line pattern indicates that system failures are remaining constant
over time - your system
is stable
· A
concave down pattern indicates that the time between failures is increasing
reliability is improving
· A
concave up pattern indicates that the time between failures is decreasing
reliability is deteriorating
Below are examples of mean cumulative function plots
for improving, stable, and deteriorating systems.
