Stat > Reliability/Survival > Repairable System Analysis > Parametric Growth Curve > Graphs
Use to create an event plot, mean cumulative function and Nelson-Aalen plot, Duane plot, or total-time-on-test plot.
Event Plot Check to display an event plot.
Display number of failures on event plot: Check to display the frequency of failures on the event plot.
Mean cumulative function (MCF) and Nelson-Aalen plot: Check to display the estimated mean cumulative function overlaid on the Nelson-Aalen plot.
Display confidence intervals on MCF plot: Check to display confidence intervals on the MCF plot. By default, Minitab plots a 95% confidence interval. You can change the confidence level in the Estimate subdialog box.
Duane plot: Check to display a Duane plot.
Total time on test (TTT) plot Check to display a total-time-on-test plot.
Display (except event plot):
An average plot over all systems: Choose to create plots which are averaged over (or pooled across) all systems. This option does not apply to the event plot.
One plot per system: Choose to create separate plots for each system. This option does not apply to the event plot.
Show graphs of different variables/by levels or systems: Choose to display the graphs overlaid on the same page or on separate pages.
X axis display (except TTT plot):
Minimum X scale: Enter a value for the minimum x-axis scale. This option does not apply to the TTT plot.
Maximum X scale: Enter a value for the maximum x-axis scale. This option does not apply to the TTT plot.
X axis label: Type the desired text to replace the default x-axis label with your own label. This option does not apply to the TTT plot.
