Stat > Reliability/Survival > Test Plans > Estimation > Right Censoring
Use the right-censoring options if your data are censored in either of these ways:
Your data can be either singly censored or multiply censored:
Type of Censoring
Time censor at: Choose for time-censored data, then enter the censoring time. If your data will be singly censored, enter one or more censoring times. If your data will be multiply censored, enter one or more columns of censoring times. Each row in a column represents a group of test units. See Time Censoring.
Failure censor at percent of units failed: Choose for failure-censored data, then enter the percent of failures at which to begin censoring. If your data will be singly censored, enter one or more percents. If your data will be multiply censored, enter one or more columns of percents. Each row in a column represents a group of test units. See Failure Censoring.
Allocation for Multiple Groups
Equal percent per group: Choose to run the same percentage of units for each group.
Percent of units run in each group: Choose to change the percentage of units run for each group, then enter the percentages.
