Calculations - Process Report
See the notation used in the equations below:
Unbiasing constants for estimating long-term and short-term standard deviation
c4(LT)j
where:
c4(ST)j
where:
Short-term standard deviation with unbiasing constant (default)
Cum SD(ST)j
where:
Short-term standard deviation without unbiasing constant
Cum SD(ST)j
where:
Long-term standard deviation without unbiasing constant (default)
Cum SD(LT)j
where:
Long-term standard deviation with unbiasing constant
Cum SD(LT)j
where:
Long-term process mean
mLT
where:
mLT  = cmLT,K
Long-term process standard deviation
sLT
Cum SD(LT)K
Short-term process mean
mST
T
If target given
(USL +LSL)
If no target given, both specs given
mLT
If no target given, only 1 spec given
Short-term process standard deviation
sST
Cum SD(ST)K
(See Centering values for short term statistics)
Capability statistics
CCpk
min
USL - mST
mST - LSL
3sST
3sST
Cp
(USL - LSL) / (6sST)
Cpk
min
USL - mLT
mLT - LSL
3sST
3sST
CPL
=    (mST - LSL) / (3sST)
CPU
=    (USL - mST) / (3sST)
Pp
(USL - LSL) / (6sLT)
Ppk
min
USL - mLT
mLT - LSL
3sLT
3sLT
PPL
(mLT - LSL) / (3sLT)
PPU
(USL - mLT) / (3sLT)
Degrees of freedom
df(LT)j
df(ST)j
Proabilities
P.LSL(LT)j
1 - F(Z.LSL(LT)j )
P.LSL(ST)j
1 - F(Z.LSL(ST)j )
P.USL(LT)j
1 - F(Z.USL(LT)j )
P.USL(ST)j
1 - F(Z.USL(ST)jj )
P.Total(LT)j
P.USL(LT)j + P.LSL(LT)j
P.Total(ST)j
P.USL(ST)j + P.LSL(ST)j
Z bench statistics
Z.Bench(LT)j
Z.Bench(ST)j
Z.LSL(LT)j
(mLT - LSL) / Cum SD(LT)j
Z.LSL(ST)j
=    (mST - LSL) / Cum SD(LT)j
Z.USL(LT)j
(USL - mLT) / Cum SD(LT)j
Z.USL(ST)j
=    (USL - mST) / Cum SD(LT)j
Z.Shiftj
Z.Bench(ST)j - Z.Bench(LT)j
Note
Cp, Cpk, and CCpk represent the potential capability of the process. Therefore, these formulas use short-term variability.
Pp and Ppk represent the actual process performance. Therefore, these formulas use long-term variability.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
