Options - Variance Pool
     example     see also
Six Sigma > Design for Manufacturability > Calculate Gap Pools > Options > Variance Pool
Allows you specify the starting values and number of iterations when an iterative method is used to determine the variance pool.
When an iterative method is used to determine the variance pool, set
The starting value at: Enter a constant to specify the starting value of the iterative calculation of the gap pool variance.
Maximum number of iterations: Enter a constant to specify the maximum number of iterations of the gap pool variance calculation.
Display iteration table: Check to display the iteration table.
