A brake manufacturer wants to investigate their process. They have collected brake shoe hardness data. This data set is used in creating the various Process Reports.
Column |
Name |
Count |
Description |
C1 |
14 |
Demographic labels |
C2 |
Hardness |
14 |
Demographic information |
C3 |
Measure1 |
50 |
First hardness measurement within a subgroup |
C4 |
Measure2 |
50 |
Second hardness measurement within a subgroup |
C5 |
Measure3 |
50 |
Third hardness measurement within a subgroup |
C6 |
Measure4 |
50 |
Fourth hardness measurement within a subgroup |
C7 |
Measure5 |
50 |
Fifth hardness measurement within a subgroup |
C8 |
Alldata |
250 |
All hardness measurements by subgroup |
C9 |
Subg |
250 |
Subgroup identification |
A manufacturer wants to investigate their process and generate various benchmark statistics for their product. This data set is used in creating the various Product Reports.
Column |
Name |
Count |
Description |
C1 |
Def |
20 |
Number of defects found |
C2 |
Unit |
20 |
Number of units inspected |
C3 |
Opp |
20 |
Number of opportunities per unit |
C4 |
Cmplx |
20 |
Complexity, the required number of elements for each assembly |
C5 |
Def2 |
120 |
Number of defects found for assembly 2 |
C6 |
Unit2 |
120 |
Number of units inspected for assembly 2 |
C7 |
Opp2 |
120 |
Number of opportunities per unit for assembly 2 |
C8 |
Shift |
120 |
A column of Z.Shift values for the components of assembly 2 |
A brake manufacturer wants to establish tolerances for each element in a brake assembly. This data set is used in the Brake Assembly example.
Column |
Name |
Count |
Description |
C1 |
Elements |
6 |
Name of each element in the brake assembly |
C2 |
Means |
6 |
Mean of each element in the brake assembly |
C3 |
Dir Vectors |
6 |
Directional vector of each element in the brake assembly |
C4 |
St Dev |
6 |
Standard deviation of each element in the brake assembly |
C5 |
Cmplx |
6 |
Number required of each element to produce a single brake assembly |
C6 |
Drift |
6 |
Ratio between the long-term and short-term standard deviation for each element |
C7 |
Lowers |
6 |
Lower gap specification |
C8 |
Uppers |
6 |
Upper gap specification |
C9 |
Mean Alloc |
6 |
Allocation weight for the mean pool of each element |
C10 |
Var Alloc |
6 |
Allocation weight for the variance pool of each element |
