Example of 1 Variance
     interpreting results     session command
You are a quality control inspector at a factory that builds high precision parts for aircraft engines, including a metal pin that must measure 15 inches in length. Safety laws dictate that the variance of the pins' length must not exceed 0.001in2. Previous analyses determined that pin length is normally distributed. You collect a sample of 100 pins and measure their length in order to conduct a hypothesis test and create a confidence interval for the population variance.
1    Open the worksheet AIRPLANEPIN.MTW.
2    Choose Stat > Basic Statistics > 1 Variance.
3    Choose One or more samples, each in a column and enter 'Pin length'.
4   Check Perform hypothesis test and choose Hypothesized variance.
5    In Value, enter 0.001.
6    Click Options. Under Alternative hypothesis, choose Variance < hypothesized variance.
7    Click OK in each dialog box.
Session window output
Test and CI for One Variance: Pin length
Method
Null hypothesis         σ-squared = 0.001
Alternative hypothesis  σ-squared < 0.001
The chi-square method is only for the normal distribution.
The Bonett method is for any continuous distribution.
Statistics
Variable      N   StDev  Variance
Pin length  100  0.0267  0.000715
95% One-Sided Confidence Intervals
                        Upper Bound   Upper Bound
Variable    Method        for StDev  for Variance
Pin length  Chi-Square       0.0303      0.000919
            Bonett           0.0296      0.000878
Tests
                             Test
Variable    Method      Statistic  DF  P-Value
Pin length  Chi-Square      70.77  99    0.014
            Bonett              —   —    0.004
Interpreting the results
Because the data comes from a normally distributed population, refer to the chi-square method. The p-value for the one-sided hypothesis test is 0.014. This value is sufficiently low to reject the null hypothesis and conclude that the variance of pin length is less than 0.001. You can further hone your estimate of the population variance by considering the 95% upper bound, which provides a value that the population variance is likely to be below. From this analysis, you should conclude that the variance of pin length is small enough to meet specifications and ensure passenger safety.
