To calculate a test and confidence interval for 1 Variance
1    Choose Stat > Basic Statistics > 1 Variance.
2   Choose one of the following from the drop-down list:
·    One or more  samples, each in a column: Choose if you entered raw data into columns and enter the column(s) that contain the data.
·    Sample standard deviation: Choose if you have summary values for a sample's size and standard deviation.
Sample size: Enter the sample size.
Sample standard deviation: Enter the sample's standard deviation.
·    Sample variance: Choose if you have summary values for a sample's size and variance.
Sample variance: Enter the sample's variance.
3    If you want to perform a hypothesis test for the population standard deviation or variance, check Perform hypothesis test, choose an option from the pull-down, and enter the hypothesized value:
Hypothesized standard deviation: Choose to test the standard deviation.
Hypothesized variance: Choose to test the variance.
Value: Enter the hypothesized value for the standard deviation or variance.
4    If you like, use any dialog box options, and click OK.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
