Stat > Basic Statistics > Display Descriptive Statistics > Statistics
Allows you to choose the statistics that you wish to display.
Mean: Choose to display the arithmetic mean.
SE of mean: Choose to display the standard error of the mean.
Standard deviation: Choose to display the standard deviation of the data.
Variance: Choose to display the variance of the data.
Coefficient of variation: Choose to display the coefficient of variation.
First quartile: Choose to display the first quartile.
Median: Choose to display the median.
Third quartile: Choose to display the third quartile.
Interquartile range: Choose to display the difference between the first and third quartiles.
Mode: Choose to display the mode and the number of times it occurs. If multiple modes exist, Minitab displays the smallest modes, up to a total of four, along with their frequency.
Trimmed mean: Choose to display the trimmed mean.
Sum: Choose to display the data sum.
Minimum: Choose to display the data minimum.
Maximum: Choose to display the data maximum.
Range: Choose to display the data range.
N nonmissing: Choose to display the number of nonmissing column entries.
N missing: Choose to display the number of missing column entries.
N total: Choose to display the total (nonmissing and missing) number of column entries.
Cumulative N: Choose to display the cumulative number of entries.
Percent: Choose to display the percent of observations that a group constitutes. The percent will be 100 unless you use a By variable.
Cumulative percent: Choose to display the cumulative percent.
Sum of squares: Choose to display the sum of the squared data values. This is the uncorrected sums of squares, without first subtracting the mean.
Skewness: Choose to display the skewness value.
Kurtosis: Choose to display the kurtosis value
MSSD: Choose to display half the Mean of Successive Squared Differences.
Check statistics
Default: Choose to check the default set of statistics as specified in Tools > Options > Individual Commands > Display Descriptive Statistics. You can check or uncheck statistics as needed.
None: Choose to clear all check boxes and then individually check the statistics to display.
All: Choose to check all boxes. You can uncheck statistics as needed.
