Display Descriptive Statistics
overview
    how to     example     data     see also
Stat > Basic Statistics > Display Descriptive Statistics
Produces descriptive statistics for each column, or for each level of a By variable.
To calculate descriptive statistics individually and store them as constants, see Column Statistics. To store many different statistics, use Store Descriptive Statistics.
Use Display Descriptive Statistics to produce statistics for each column or for subsets within a column. You can display these statistics in the Session window and optionally in a graph (see Descriptive Statistics Available for Display or Storage).
Variables: Choose the columns you want to describe.
By variables (optional): Enter the column containing the by variables to display descriptive statistics separately for each value of the specified variable. Column lengths must be equal. See Graph Limits for limitations associated with using a By variable.
<Statistics>
<Graphs>
