Stat > Basic Statistics > Graphical Summary
Use to produce a graphical summary for each column, or for each level of a By variable.
The graphical summary includes four graphs: histogram of data with an overlaid normal curve, boxplot, 95% confidence intervals for m, and 95% confidence intervals for the median.
The graphical summary also displays a table of:
Variables: Enter the columns for which you want to create a graphical summary.
By variables (optional): Enter the columns containing the by variables to create separate graphical summaries for each level of a grouping variable. Column lengths must be equal. See Graph Limits for limitations associated with using a By variable.
Confidence level: Enter a value for the confidence level for the confidence intervals. The default level is 95%. Specify any number between 0 and 100. For example, entering 90 generates 90% confidence intervals for the mean, median, and standard deviation.
