Paired t
overview
     how to     example     data     see also
Stat > Basic Statistics > Paired t
Performs a paired t-test. This is appropriate for testing the mean difference between paired observations when the paired differences follow a normal distribution.
Use the Paired t command to compute a confidence interval and perform a hypothesis test of the mean difference between paired observations in the population. A paired t-test matches responses that are dependent or related in a pairwise manner. This matching allows you to account for variability between the pairs usually resulting in a smaller error term, thus increasing the sensitivity of the hypothesis test or confidence interval.
Typical examples of paired data include measurements on twins or before-and-after measurements. For a paired t-test:
H0: m d = m 0     versus     H1: m dm 0
where m d is the population mean of the differences and m 0 is the hypothesized mean of the differences.
When the samples are drawn independently from two populations, use Stat > Basic Statistics > 2-sample t.
Each sample is in a column: Choose if you have entered raw data in two columns.
Sample 1: Enter the column containing the first sample
Sample 2: Enter the column containing the second sample
Summarized data (differences): Choose if you have summary values for the sample size, mean, and standard deviation of the difference.
Sample size: Enter the value for the sample size.
Sample mean: Enter the value for the mean.
Standard deviation: Enter the value for the standard deviation.
<Options>
<Graphs>
