Stat > Basic Statistics > Paired t > Options
Select among options for the confidence interval and hypothesis test.
Confidence level: Enter the level of confidence desired. Enter any number between 0 and 100. The default is 95%.
Test mean: Enter the null hypothesis value, which is the hypothesized population mean of the paired differences. The default is 0.
Alternative:
Choose the form of the alternative hypothesis: Difference< hypothesized
difference (lower-tailed), Difference hypothesized difference
(two-tailed), or Difference > hypothesized difference (upper-tailed).
The default is a two-tailed test. If you choose a lower-tailed or an upper-tailed
hypothesis test,
an upper or lower confidence bound will be constructed, respectively,
rather than a confidence interval.
