When you include a categorical predictor in your binary logistic regression model, Minitab assigns one categorical level as the reference level. Minitab designates the reference level based on the data type and coding scheme. You can choose the coding scheme in the Coding subdialog box.
For -1, 0, 1 coding:
For 1, 0 coding:
If you choose 1, 0 coding, you can change the default reference level in the Coding subdialog box.
Regression creates a set of design variables for each categorical predictor in the model. See Coding categorical predictors in Regression for examples.
When your data are in binary format or frequency format, Minitab needs to designate one of the response values as the reference event. The default reference event depends on the data type:
You can change the default reference event in the main dialog box. To change the event, specify the new event value in Response event. To change the order of response values in ordinal logistic regression, specify the new order in the Order of the response values box.
If you have defined a value order for a text factor, the default rule above does not apply. Minitab designates the last value in the defined order as the reference event. See Ordering Text Categories.
