Regression Overview
Regression analysis is used to investigate and model the relationship between a response variable and one or more predictors. Minitab provides the following regression procedures:
·    Least squares: Use when your response variable is continuous.
·    Nonlinear regression: Use when you cannot adequately model the relationship with linear parameters.
·    Orthogonal regression: Use when the response and predictor both contain measurement error.
·    Partial least squares regression: Use when your predictors are highly correlated or outnumber your observations.
·    Logistic regression: Use when your response variable is categorical.
·    Poisson regression: Use when your response variable counts occurrences.
Both least squares and logistic regression methods estimate parameters in the model so that the fit of the model is optimized. Least squares methods minimize the sum of squared errors to obtain parameter estimates, whereas Minitab's logistic regression obtains maximum likelihood estimates of the parameters. See Generalized Linear Models Overview for more information. Partial least squares (PLS) extracts linear combinations of the predictors to minimize prediction error. See Partial Least Squares Overview for more information.
Use the table below to select a procedure:
Use...
To...
Response
type
Estimation
method
Regression
perform simple, multiple, polynomial, and stepwise least squares regression with continuous and categorical predictors
continuous
least squares
Best
Subsets
identify subsets of the predictors based on the maximum Rimage\SQUARED.gif criterion
continuous
least squares
Fitted Line
Plot
perform linear and polynomial regression with a single predictor and plot a regression line through the data
continuous
least squares
Nonlinear Regression
perform simple or multiple regression using the nonlinear function of your choice
continuous
least squares
Stability Study
analyze the stability of a product over time and determine the product's shelf life
continuous
least squares, Restricted Maximum Likelihood (REML)
Orthogonal Regression
perform orthogonal regression with one response and one predictor
continuous
orthogonal
PLS
perform regression with ill-conditioned data
continuous
biased, non-least squares
Binary
Logistic
perform logistic regression on a response with only two possible values, such as presence or absence
categorical
maximum
likelihood
Ordinal
Logistic
perform logistic regression on a response with three or more possible values that have a natural order, such as none, mild, or severe
categorical
maximum
likelihood
Nominal
Logistic
perform logistic regression on a response with three or more possible values that have no natural order, such as sweet, salty, or sour
categorical
maximum
likelihood
Poisson Regression
perform Poisson regression on a response that counts occurrences
discrete
maximum likelihood
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
